Generally, I am not fond of the rim weights, but this design once for a change makes some sense - it is acrylic or some similar material ? It is the nicest variation on the theme I have seen so far.
Still, I prefer vacuum to flatten my LPs. After I first experienced with Versa Dynamics tables, I knew one day I will have to get some vacuum suction device. It uses air pressure to press your record against the platter, flattening it in the process. Not with a couple of kg of force for the rim/clamp, but approx 250 kg due to vacuum and atmospheric pressure difference !
The most easily available is Audio Technica AT666EX http://www.soundscapehifi.com/used-at-stabilizer-001.htm Here YT vid for 665BX which is basically the same thing, but with less clutter and more comfort http://www.youtube.com/watch?v=eijU5LjvjNA
Here my second S/H sample that arrived yesterday, but got demaged at the rim during transport due to insufficient padding :
The box to the left of the TT is AT 661 vacuum pump . Upper close up showing vacuum valve closed, lower one open ( release )
Suction valve, where the hose is attached
...and what I will have to "live (un)happily ever after" with - because it is next to impossible to get people to pack as per instructions...
Rule # 1 for shipping : regardless what are you shipping, pack it so that it will securely survive fall from the 1 meter height - from any possible angle.
If you stiill wonder why you MUST do it even if you declared it as fragile, stamped "This side up", etc - enjoy watching :
http://www.youtube.com/watch?v=U9JRmgo77D4
http://www.youtube.com/watch?v=wq6u8JU6v4E
DHL are certainly not the only ones to blame, but they menaged to demage a perfectly good 30 years old AT666EX this time. It is still functional, yet at every look of the turning platter I will get reminded ...
