aj-kun
- Aug 7, 2009
Update 19 Sep 09
Heres a concept I did on MS PAINT as thanks for all your replies
ENJOY.
AJ Lazaro©
It's not really clear, but the bottom part has headphone out, usb for i/o(DACmode) and line out jack(obviously redundant, coz of the internal amp but for users who will connect to their home amp). This bottom part can be unscrewed and pulled out, thats where I proposed will be the amp section, with a similar formfactor to the Emmeline shadow amp. Ideally it would beable to be swapped out ala HIFIMAN, no op-amp rolling in this design, I doubt it could be supported at this size. The screen is oled capacitive touchscreen...with oleophobic coating. Playback buttons on the side for blind control.
No external gain switch...because I imagine in one's pocket that could poke, be broken, or change by itself...(*hint**hint* amp designers)
Ideally the dimensions would be around 0.5"x1.45"x3"
After drawing it I realised that I havent address volume control...and the fact that ergonomically, it looks like it's made for a left hander(when you see it...). Oh and the weird line in the middle of the bottom part, is coz I tried to render chrome and failed.
Original 16 Sep 09
Hi Head-Fiers,
I'm currently doing an Product Design project for uni and was wondering if you guys could help me out in regards to my design.
The project is to design a portable audio player for a user group, and my user group happens to be audiophiles like yourselves.
So if you could fill out one of these little surveys that would be great.
Portable Player Survey:-
What is your current portable audio player?:
Do you use it with an amp?:
If so does it fit in your pocket?
Do you use headphones or IEMs?
What do you like about the controls?
What do you hate about the controls?
Can you use it blindly, without looking at the player, to change songs?
Does it have packaged software? What do you like or hate about it?
Is downloading music to the player an easy process? what can be made easier?
Can you sync your player wirelessly with your computer?
In general what do you like about your player?
In general what do you hate about your player?
Any suggestions?
Thankyou,
AJ Lazaro©
Original 16 Sep 09
Hi Head-Fiers,
Any suggestions?
Thankyou,
