castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
I'm not sure specs really tell you that much about the sound of gear-sure, an obvious horrible spec could mean trouble, but even manufacturers of cheap gear know how to put up good specs. And, in the tube vs solid state world, or the digital vs analog world, specs are on the side of solid state and digital, but many audiophiles would argue the sound is better from tubes/analog, specs be damned! just sayiin'
well most will cheat on the specs, so just like the loudness war, in the end they all use about the same tricks(distortion only at 1khz. imd? ooops I forgot^_^. frequency response with no load, and other such silly lowlife marketing tricks) so you end up with an OK way to compare 2 gears with 2 similarly pimped specs ^_^.
still thd+N and impedance tell me a great deal about what kind of IEM I can use(hiss or signature change), and max voltage into a load or power output give me a hint on what fullsize headphone it may or may not drive. so I do find specs interesting and important.
now about taste and favored sound, obviously measurements can't do much for a DAP as they all at least pretend to have dead flat signature and low crosstalk(forgetting to tell us that it may becomes a mess with a 16ohm IEM^_^).
ah well I certainly wouldn't cry if the audo world stopped lying about everything. I feel like a homeless guy begging for specs and knowledge: spare some change or an impedance value?
