reminence
- Aug 28, 2008
Hi Guys,
I have owned Heaps of typical DJ headphones over the years and my last Audio Technica ath700 pro's are failing in one ear and now i need an upgrade/replacement!
I want the best headphones for Dj'ing and unfortunately the top of the range headphones will lack the amount of bass I'm looking for, namely the hdj2000's. So due to this problem I have decided to explore the rest of the closed headphones available (non dj design). When i DJ, at most i move one earphone off to the side an nothing else fancy, so I should be able to get away with normal closed and well isolating headphones.
I own a pair of Senhiezer IE8 in ear monitors and love them to bits, if the bass know could go further than the maximum i would make it do so!!! I love my bass but really only the non punchy low stuff below 60hz and would love to find this in a great pair of headphones. I am looking for a good quality sound as well but predominantly looking for that bass. A headphone that is similar to the IE8's with the bass know on full would be sorta what im looking for.
Lastly they need to be quite sturdy as i use them heaps and they get carried around a lot.
Listing requirements in order of preferance
- Bass 10-80hz must be very very prominent
- closed design, great at isolating sound
- great soundstage and overall clarity
- sturdy construction (built to last)
- look pretty awesome!!
So what do you think I should be looking at?
