false
- Jul 19, 2004
To make life even easier for you here is an another way to check. Its so easy it I could cry...
1. Right click any wma and select "properties"
2. There will be two tab's available. Select "summary"
3. On the summary there will be and "advanced" option. Press that button.
4. Scroll to the bottom of the summary and check you bit rate.
It should look like this...
Once again, even with WMA files the lower the number, the worse the sound. 128 kbps is NOT GOOD. Even with all the other gear everyone else in the the thread suggested, if your source audio files are crap, they will still sound like crap on good equipment. With your RS-2's you get to hear just how NOT GOOD your mp3's (or wma's) are.
![wma_options_02.jpg](http://photo.head-fi.org/data/500/wma_options_02.jpg)
