110mm.Thanks! What diameter/size did you get 95mm?
Pioneer's First Hi-End Headphones: SE-Master 1
- Thread starter Edric Li
Chris Kaoss
Curious how they'd fit on the SEM5.Sure get the link https://sl.aliexpress.ru/p?key=fXJwJC
Thank you for heading up with, looks great.
Man, I really appreciate this. It's great to finally get a suitable set of leather pads for my SEM1's . Have you noticed any sonic changes with the new pads or does everything sound the same?110mm.
The sound has changed a bit. A little more bass. The middle is just as clear and transparent. High frequencies, it seemed to me, decreased a little on some tracks, excessive brightness was gone. Resolution and detail at the same level. I also want to note, again, according to my feelings, this increase in the depth of sound.Have you noticed any sonic changes with the new pads or does everything sound the same?
Nice, I ordered my set. Now the wait begins. The way you describe the sound is exactly what I wanted to hear, thanks for the update!The sound has changed a bit. A little more bass. The middle is just as clear and transparent. High frequencies, it seemed to me, decreased a little on some tracks, excessive brightness was gone. Resolution and detail at the same level. I also want to note, again, according to my feelings, this increase in the depth of sound.
Have anyone with the Master 1 tried the new Meze 109 Pro headphones?
My Master 1 has arrived today. I missed this great sound the headphones are capable to reproduce.
Now I am waiting for my lamb leather earpads to arrive and also to find a place where they can make a custom leather headband for maximum comfort. Thinking of getting Forza Audio cable too.
jamato8
What earppads are you getting? Do they have any fenestration? That is what I found to be important with the Pioneer. The headband on mine need replacement. I most likely will make one as I used to do leather work professionally. But I don't enjoy it like I used to. I can believe how cheaply the headband was made, to start breaking down in a couple of years of being new. Otherwise, besides the earpads and headband, which break down, the Pioneer seem to be very well made.My Master 1 has arrived today. I missed this great sound the headphones are capable to reproduce.
I am getting this genuine sheepskin earpads:
US $15.66 13%OFF | Sheepskin Angled Diameter circle Bevel Ear Pads Leather Round earpad 90MM 95 100MM 105MM 110MM 115MM 120MMHeadphones Ear Cover
https://a.aliexpress.com/_uXJxJ1
110 mm diameter and they are not fenestrated. Maybe in the future I will experiment with others. If you have skills to make headband of high quality leather maybe you consider doing few and selling to some of us interested? That will be much appreciated.
I love the sound signature and if things can be improved I would love it even more for a long time.
jamato8
I look forward to your impressions.I am getting this genuine sheepskin earpads:
I still have my equipment, sewing machines etc., but no desire. And besides then I might be tagged as member of the trade as they do here, and no desire for that. Any good leather worked could make the headband with the dimensions given.
New pads definitely alter the frequency response some. Mainly in the mid to upper frequencies. It’s sounds like some of the clarity has been taken away. I need to listen more to put my finger on what’s changed in the sound.Left new genuine leather, right fake leather.
jamato8
What kind are you using?New pads definitely alter the frequency response some. Mainly in the mid to upper frequencies. It’s sounds like some of the clarity has been taken away. I need to listen more to put my finger on what’s changed in the sound.
snapple10
Still waiting on new pads here, ( thanks for the share). But I find I mostly fail blind tests as far as pads and cables are concern, which can be a good thing
Total: 6 (members: 0, guests: 6)
