How do you like 300R with meze 99c, enough power- loudness to drive them?Yes, the 300 plays MQA
Pioneer XDP-300R | Twin DAC ES9018K2M | Balanced Out | Android | MQA | 2x MicroSD | WiFi | AptX
Lurk650
99C are very easy to drive. Sounds great with the 300R and BW Oval Sheepskin padsHow do you like 300R with meze 99c, enough power- loudness to drive them?
Angled or not angled sheepskin pads?99C are very easy to drive. Sounds great with the 300R and BW Oval Sheepskin pads
Lurk650
Not angledAngled or not angled sheepskin pads?
Ang Probinsyano
- May 1, 2017
@Lurk650 How's the synergy of pioneer ch9t and 300r? Are you using it in balanced?
But does it has enough power to play loud with meze99c as i read and also heard pioneer 30r, it was just lit bit louder than my iphone se. Maybe the setup on 30R was power saving? If 300r plays really solid and loud i would ho for it or it need amp?99C are very easy to drive. Sounds great with the 300R and BW Oval Sheepskin pads
- Dec 27, 2010
My 300r just stopped working...it ran out of charge, I plugged it in, and now it doesn't start. Any way to get it going anyone knows of?
(never mind, must have been some problem with the charger, I connected to my computer, and it did charge and start... )
Lurk650
I only use my CH9T with my Fiio M3 at the gym.@Lurk650 How's the synergy of pioneer ch9t and 300r? Are you using it in balanced?
It will get loud enough and the 300R SQ will crap all over the iPhone SE. I run my 300R on High Gain and volume is usually around 110/160 and I listen to my music pretty loud compared to other peopleBut does it has enough power to play loud with meze99c as i read and also heard pioneer 30r, it was just lit bit louder than my iphone se. Maybe the setup on 30R was power saving? If 300r plays really solid and loud i would ho for it or it need amp?
I'm in the same boat like you, maybe already chose and has or tested of your mentioned daps? If yes which you prefered? Thanksdp-x1a has more memory, I prefer the looks of the xdp-300r, and no one knows about the fiio x7 mk2 yet, but the x7 was plagued with issues.
As understood cause was reading all post you chose 300rI'm in the same boat like you, maybe already chose and has or tested of your mentioned daps? If yes which you prefered? Thanks
BobJS
I just got one of these new. Sounds fine out of the single ended 3.5mm jack. I notice there's a headphone icon in the android status area.
I got a (2.5mm) balanced, MMCX cable yesterday and put my SE846 on it. When I plug into balanced output, I get no sound. I notice also there's no headphone icon in the Android status area. The output is still set to 'balanced'.
This was a bit late last night so I didn't have time to troubleshoot yesterday, though today when I get home from work I'll buzz out the balanced cable to make sure all the conductors are good. Assuming the cable is good, am I missing anything obvious (like a setting), or do I have a dud I need to return and exchange for a new unit?
Thanks... !
Thanks... !
Thanks... !
I think you have it covered Bob, set Balanced or ACG mode and it should just work. There are at least two different configuration options for a 2.5 mm balanced plug so you probably have the wrong one.
BobJS
OH! Thanks Steve ..... I wasn't aware there were different pinouts. Are you saying that your diagram shows the expected pin map for this DAP? When I googled, I saw (in TRRS order) L+, R+, L-, R- . Which made sense to me because if that were plugged into a single ended output, the 2 grounds for each channel (might) be both connected together.
I'll buzz out the one I have, but if it matches your diagram, THEN I can assume there's something wrong with the DAP. Otherwise, I have the wrong type cable. Right?
Yes the Pioneer/Onkyo DAPs use the Astell & Kern 2.5mm pinout, which the one I posted above, I think its the most common 2.5mm balanced pinout now.
- Dec 27, 2010
I didn't even realize there was more than 1 2.5 mm connector...
