Apr 20, 2013 at 12:59 AM Post #3,497 of 37,685
I think this is good enough for a 17-year-old...
FitEar ToGo 334 + ALO Audio Cryo L.O.D. SXC 18 (not in use) + iPod Classic 160GB + MacBook Pro 15" Retina
Glad you're happy with your TG334s! Happy Listening!
Here's my DX100, got from repair last Thursday with EX1000, M-100, all with ones and zeros.
size]
Apr 20, 2013 at 5:53 AM Post #3,498 of 37,685
Thanks! Tera Player pair nicely with SE5 (133ohm). Vorzuge takes it even further. You have to watch out pairing TP with low impedance headphone though, the output capacitor cut the bass response for headphone with less than 50ohm impedance.
Beautiful. I hope to hear the Tera at the London meet. Who knows it may replace my dx100. As for the spirals, if I was to go custom, they are number 1 on my list. Very nice setup man.
Apr 20, 2013 at 10:35 AM Post #3,500 of 37,685
Went from iMod + RSA P-51 to AK100. Minimalistic ftw!
Only on Head-Fi is a $600 source and CIEMs is considered minimalistic.
Apr 20, 2013 at 11:30 AM Post #3,503 of 37,685
I ordered MUSES01 but replaced it with MUSES02 from my Blue version. Now, I have two different OpAmps to play with. After ABing it, I can say that the sound seem fuller and cleaner on LE. Bass got more details while treble got slightly cleaner. Both Blue and LE still have the same power rating. 9V and 12V are referred to the voltage that supplied the OpAmp.
Do you use on your go dap dd1 le with muse 02 or op amp 627 ?
Thank you
Apr 20, 2013 at 11:35 AM Post #3,504 of 37,685
Hi. Can you share what is this adapter and what does it do?
Sorry for late reply
This 6,3 mm to mini 3,5 mm adapter is DIY by my friend
The good think with this cable from him , if I make the cable wider from each other , can effected to SQ more separation and more detail,compare if I put near to each other .
I don't know what kind if cable my DIY friend used it
I try with other cable the effect is not the same like his cable
Apr 20, 2013 at 11:41 AM Post #3,505 of 37,685
Looks like a balanced XLR to unbalanced TRS adapter to me.
And please let us know what the little coils of silver wire every 6 inches are for? Some sort of sonic resonator or filter I assume?
Sent from my HTC Desire HD A9191 using Tapatalk 2
These little coil cable for my LCD 2 stock cable has the function to reduce Eddie current in my cable .
I have already post this coil in cable thread few month a go .
Please try it , you will see the effect for your SQ
You can do for all your headphone or iem cable as well
Apr 20, 2013 at 11:48 AM Post #3,506 of 37,685
IPC160 + Apex Glacier + HPP1 as DAC + SM64V2
IPC160 + RxMK3 + HPP1 as DAC + HD650 with Toxic Silver Cable
Tell me about your RXMK3 - looks like it has a bass potentiometer. How do you like this amp?
Apr 20, 2013 at 12:22 PM Post #3,507 of 37,685
I think it is a 6.3mm->3.5mm converter. It;s just that it is still naked
I think you'll find its a large female stereo jack to mini stereo jack adaptor chaps :)
This is from my DIY friend special cable adapter 6,3 mm to 3,5 mm .
His cable is special , because if I put together the soundstage so narrow , if I make it far from each other I get wider soundstage .
Apr 20, 2013 at 12:27 PM Post #3,508 of 37,685
iPod Classic --> CLAS --> AHA-120 --> T5p
Apr 20, 2013 at 1:08 PM Post #3,509 of 37,685
