Jun 30, 2016 at 8:17 AM Post #20,448 of 39,035
Jun 30, 2016 at 11:07 AM Post #20,449 of 39,035
Jun 30, 2016 at 11:24 AM Post #20,450 of 39,035
I had already owned the Mojo and an Ak100II, I just sold the AK100 and purchased the AK300 with less than 200 bucks out of pocket.
It's not about flavor. The Mojo sounds better period when compared to the AK100 II or the AK300. What it does for me, is allows me to travel without the Mojo now because I get closer in sound with the 300, but not all the way there. And the upgrade didn't cost me as much.
i was gonna comment and say thats one expensive transport but then i saw your reply.
oops i think i just did! lol
Jun 30, 2016 at 2:27 PM Post #20,452 of 39,035
Here's a ponoplayer hooked into iHome wireless speakers through the USB port.  perfect little pool-side sound system!
Jun 30, 2016 at 8:31 PM Post #20,456 of 39,035
How does the JH Angie II sound with Mojo? I loved how its SQ with Onkyo DP-X1 the other days at CanJam SoCal 2016.
I guess the best way to describe the sound of the combo is as follow. The Angie's are very mid vocal centric with killer highs. The Mojo if I were to compare them against just the sound of the AK300 is, that at higher volume were I like to listen. The Mojo always keeps its detail retrieval and never losses it's control.
If you like your music with excellent detail, great retrieval, great instrumentation seve ration then I highly recommend the combo.
Jun 30, 2016 at 8:55 PM Post #20,457 of 39,035
Jun 30, 2016 at 10:00 PM Post #20,459 of 39,035
Pelican micro case owners - Are the optional foam inserts for the 1010-1060 cases pre-cut into the same dimensional cubes, just that there are less/more of them included? If not, would it be better to get the smallest size foam inserts (1012) for a more precise fit? I know they can be cut by the end user, but I'd rather not.
Jun 30, 2016 at 11:16 PM Post #20,460 of 39,035
The foam rips clean apart in centimeter-size squares. It's very easy to work with. Just get the size that fits your case.
But I would suggest you get two sheets, just in case you make some poor design choices the first time... like I did. It's hard to be sure exactly what you need without a little trial and error.
