HipHopScribe
the earpads are different, which can change sound quite a bit. also since they are removable, I can see how my other pads do on it with double sided tape.
In my experience they're not different enough that it makes a significant change in sound, especially since the X2s aren't as seal-dependent as some headphones, it's not like swapping out to a very different material or depth in terms of effect, but your mileage may vary
