Oh a and can anyone recommend a nice hard case for these?
Philips Fidelio X2?!
- Thread starter thatBeatsguy
WildStyle-R11
- Nov 6, 2012
July 2015, only started using them this year, after I got my ADI 2 ^^ It sounded bad from previous amp. ^^The reason is always apparent - they are just that good! October 2014 pair here.
Also main reason for not getting a second pair? X3 will be soon released.
MisterMudd
I will likely pull the trigger on X3. If nothing else just out of curiosity. Can always sell them.July 2015, only started using them this year, after I got my ADI 2 ^^ It sounded bad from previous amp. ^^
WildStyle-R11
- Nov 6, 2012
Well the hope is they take what they have and make it better.
I use this for my X2. I just took the foam out and replaced it with micro fibre cloth.Oh a and can anyone recommend a nice hard case for these?
US $11.52 25%OFF | Headphone Case Cover Headphone Protection Bag Cover TF Cover Earphone Cover for Sennheiser HD598 HD600 HD650 Headphones Earphone
https://s.click.aliexpress.com/e/lPwdQPSY
Thanks for the link. Looks like it might be the one!I use this for my X2. I just took the foam out and replaced it with micro fibre cloth.
Are the pads glued down or did they just pop out of the care?
They are removableThanks for the link. Looks like it might be the one!
Are those worth buying nowadays?
I’ve only had them a few days but I am enjoying them.Are those worth buying nowadays?
WildStyle-R11
- Nov 6, 2012
That only depends if you like them or not. They haven't gotten worse. Only now they don't cost as much.
bezlimitchyk
Yes, they worth buying nowadays,
I believe I bought them for less than $200
Of course, listen to them first
Slater
It’s not like an iPhone or gaming video card. Dynamic drivers have changed very little in 100 years. The X2 was great 5 years ago, and it’s still great today. If you can buy it below $200, jump on it. I was lucky enough to get mine for $150.
ArlakTheRecluse
Okay after breaking these bad boys in for a while
I can safely say these are completely awesome.
Sound is amazing for what I listen to (a mixture of most things, but to name a few specific artists and bands, Perturbator, Scattle, Metalica, Earth Wind and Fire, Marty O'Donnell)
Can wholeheartedly recommend these, especially for people just getting into fancier audio.
Ayax
- Dec 15, 2011
Joshua Velour just reviewed X2HR.
