Mr Trev
Quite possible. It was mentioned a bit ago that a revised version was supposed to be released sometime this year. Haven't been able to find much info myself tho
Amazon is all out, are these discontinued?
Guys I need your help. I'm on my third set and I finally found one without driver imbalance. I'm in love with the sound, only one problem.
It's used and the metal bolts are loose. Not the black plastic ones on the outer rings (I know they're fake), the ones connecting the outer ring to the metal headband. Basically the entire left earpiece is about to fall off, outer ring included, and I guess as long as they don't come more loose I should be fine since it's metal but it's really disheartening as I've been chasing a good set for quite a while and finally found one.
Anyone know of a small enough tool to get in and tighten them, or a guide for proper disassembly so I can get in and properly secure them?
Cheers!
Anybody hear if/ or how much the new earpads will be selling for? (assuming they're still replaceable)
Just use a pencil eraser end (or wooden chop stick) and reach in and tighten the loose bolts. Wiggle the ear cups slightly as you tighten them up. This will have to be done every month or so but it's not really a big deal IMO. Just a little preventive maintenance every so often. . .
If the hd600 is soft then the hd650 may be the sameWich would suit a hd25-1 ii, m50x and momentum over ears better.... A x2 or a hd650? I mostly listen to metal and edm.
I havê the hd600 but it males my ears ring and itsna bit soft for my taste....
