Xcaliber
- Dec 30, 2016
Are digital EQs no option for your situation? I'd try to find a solution there before I spend money on gear I might not even need. Most Playback Apps on phones support equalizing in some form.
Since I use my cans on PC only, and I also had the problem with sensitive treble, I used "Equalizer APO", which I originally only got do channel balancing. And I do use the Fiio E10k, which also has pretty sharp trebles. Using that software I was able to go from painful to enjoyable without losing a penny.
As a side note, one hour of pink noise is essentially nothing for a burn-in. Give it a full weekend and you might hear a difference.
Yea I'm using Boom 2 on the mac and it works wonderfully. I had to start rolling off at 8K. Unfortunately there is no systemwide EQ for iOS unless you jailbreak
