Alright, I've been playing around with "recording my headphones" to nail down the balance issues once and for all, because although this third pair I have isn't even close to what the other two ones had, I still sense the slightest imbalance in the treble. I thought my mind was going insane from all this ordeal, but I wanted to let it rest once and for all, and EQ out these subtle differences.
So I had to measure them.
Using Audacity's built-in sine wave generator:
- Logarithmic
- 10-20000 Hz
- 0.8 amplitude
- 30 seconds
The microphone I've used is the
Blue Snowball iCE, which obviously isn't a top-of-the-art microphone, but it certainly is decent enough. Also, it's just barely the size to snuggly fit into the cups of the X2.
I've recorded both sides five times, each time taking the microphone out and putting it back in. This was to avoid affecting the results by me improperly placing the microphone. I then visually matched the two most identical ones for each channel.
These are the result graphs:
And this is a difference graph between the two channels:
Analysis:
- Right off the bat we can see a pretty consistent loudness difference with that white line throughout the graph. But okay, that could be caused by the microphone placement, and even then it would be easy to balance out alone.
- Otherwise, things are pretty consistent for the two channels for the majority of the bass region.
- But then it gets weird at around 200-240 Hz, where there's a slight bump on the Left side where there's only a tiny one on the Right side.
- Then we get a whole bunch of consistency again.
- When finally, oh god, everything is mismatched in the 4000+ Hz region. The general structure is the same at first glance, but there are artifacts on the left channel where there isn't anything on the right one and vice versa.
What can I conclude? Well... the EQ'ing is likely going to be tougher than I thought. Waaay tougher.
