Looking to get some guidance here as i'm looking for a pair of headphones that are well rounded and suited for all types of use. I've read the X2s are not proficient in any one area but does everything well, which makes them sound like they're what i'm looking for.
First let me give a little background of what I've used in recent history. For a long time i used a pair of plantronics gamecom 780s, a gaming headset that was adequate for the years it lasted, but i knew there was better out there so i started looking into getting my first pair of audiophile grade headphones.
First came the HD558s, huge upgrade, in fact i'd still probably be using them if not for the fact that i couldn't easily attach my V-moda boom pro mic to turn it into a headset essentially. I opened the cans up and did the foam mod on them as well as removed the locking ring mechanism in order to use a made 2.5mm to 3.5mm female adapter to use the mic with but i had an issue of audio cutting out of one cup. It may have been due to a really cheap adapter, but at that point i was fed up with it and decided to find headphones that had a 3.5mm jack to begin with. Mind you i really loved the sound of the 558s for what i threw at it and didnt feel that it was lacking in any area really.
Next came the Phillips SHP9500s which is what i'm currently using. I read all the hype around these and they seemed to fit the bill for what i was looking for. Sure enough these headphones have been amazing, with two quibbles. First is they're clamping force is really weak so it does slide off if you tilt your head forward, but i guess if the clamp was stronger they wouldn't be as comfortable so i can forgive it for that. The other problem i have is i find the bass to be severely lacking especially compared to the 558s and they're not exactly basshead phones either.
I went ahead and ordered a pair of 598s to do some AB testing, and the 598s to me blow the Phillips away with bass that has good quantity and impact, probably helped by its stronger clamp and better isolation. The X2s have piqued my interest because they're supposed to have very good bass for open headphones while not exactly being basshead, and i'm not looking for crazy bass otherwise i would go for closed backs and i absolutely hate their sound. Between the 598s and SHP9500s i think they both sound great, with the phillips being a bit clearer and brighter, but find the 598s way more fun for listening to music thanks to the added bass.
Would the X2s be a good fit for what i'm looking for? Just from what i've read about them sounds like they're the bees knees when it comes to value and how fun they are to listen to. I'm also curious to know whats the deal with all the reports on Amazon of folks getting seemingly defective X2s with glued pads and poor QC in general? I think i would have ordered them already and just gave them a shot without asking for further encouragement here, but i'm worried about getting a bad pair.
