Really enjoying my X2's now. I had to EQ them in foobar2k (which means I can only listen to them with music through FB2k
![Frowning2 :frowning2: :frowning2:](https://cdn.head-fi.org/e/people/frowning2.svg)
) I turned 55hz up, 80hz up slightly, and turned 14khz down slightly. Sounds like the pair I had before with flat EQ now. Also running amp on "pure mode".
I got the pads off in the end, no glue...just really hard to come off like they were sealed on. This has really changed the dynamic of the sound...before it sounded muffled, now less so. With EQ I have the sub-bass I crave back.
I think the amp isn't very good or atleast the headphone amp part of it isn't. LOTS of source noise, when I pause the music I can hear noise in the background, if I turn the amp down the noise goes...but then it is not loud enough for normal use :/
Listening to Depeche Mode, Ultra, 2007 SACD edition at 2852kbps...excellence.
