guido
- Jul 3, 2003
How does the X2 compare to the L2?
aha yes, thanks....I just read all the comments regarding an X2 - L2 comparison...seems like there is nothing conclusive about which is better.
I wrote a short comparison of a few hp's including the x2 and thought that I'd post it here.
Okay, I feel that the x2 has settled into the final signature for the most part. Here's a few thoughts on the hp's that you mentioned:
hd650:
*fantastic mids and tone-voices and instruments are strikingly realistic and musical
*although the treble is not as pronounced as some, this headphone does resolve the music very well...and offered a nicely layered presentation when a good amp is imployed
*there is more mid bass than true sub bass; this is referred to as a mid bass hump. IMO this is not necessarily a short coming because it tends to give the music a little life and punch and works well within the constructs of what the 650 sets out to accomplish
*average sound stage
*does well with nearly any genre excluding classical
*wonderfully comfortable and rugged built quality despite the plastic materials
he400:
*truly supreme sub bass; the bass here is audiophile quality with texture and finesse...not just one note bass by any means. And the bass quality competes with hp's costing $1k+ (lcd2.2)
*the mids are somewhat recessed and not tonally correct
*treble is peaky and fatiguing
*somewhat heavy at 440 grams
he400i/he500:
*I lump these two together because they are voiced very very similarly
*very balanced across the spectrum.
*treble is slightly dark for a hifiman hp but not compared to most others
*nice deep sub bass with impressive extension
*both hp's have planar mag speed and decay and will make dynamic driver hp's (hd650) sound slow in comparison
*mids are balanced to the rest of the spectrum and tonally accurate
*the 500 trumps the 400i on sound stage
Overall I'd rate the he500 slightly ahead of the 400i on refinement of the signature but they are very close. I'd tend to choose the 400i because of the newer more comfortable design and greatly reduced weight.
And finally...
x2:
*out of the box the x2 has a mild "u" shaped frequency with punched up bass and treble. This is alleviated about 90% after about 150 hours of burn in where the signature becomes mostly balanced
*amps incredibly easy with any gear, but tube amps will make the x2 overly warm
*the sub bass tightens up after the burn and sounds like a pair of expensive subwoofers in a well treated room...never too boomy or loose. The bass also responds well to the recording in a linear fashion, giving you more when it recording calls for it and less when it doesn't
*the mids are good and have decent tone if not somewhat grainy especially when compared to the hd650
*treble has good extension but is not harsh or strident once burned in
*much better than average sound stage
*wonderfully comfortable and ergonomic memory foam ear pads
*build quality is tank-like but with a dash of sophistication...nice metal construction with leather appointments. The headband is large and garish looking
*I'd compare the x2 to another hp not mentioned so far, the he560. You might consider them a dynamic driver version of the he560. While the x2 does not equal the 560 it certainly gets you in the neighborhood and for a lot less money
Well written, informative comparos, thx for share
I just spent the past hour or so listening with the x2 to Mark Knopfler: Privateering 24/96. I've listened to this album 50+ times. This may have been the most I've ever enjoyed it. I loved the sense of space on this album on the x2, especially when Mark is playing the acoustic guitar. I spent much of my youth listening to my dad and his friends playing acoustic guitar...or "picking" as they call it. All those years have trained me to listen to the tone and timbre of the guitar and I have a fairly good sense of when it sounds natural and doesn't.
The bass presence on this well recording album is spot on. Not overpowering but visceral and present. The x2 reproduces the bass wonderfully. Just smooth and tight. I love how the bass hits on this hp. It doesn't bleed into the mids but stays accurate and punchy.
Give this recording a listen if it's not on your playlist already.
Would you recommend these over the HE-400s?
In a word, yes. In two words, hell yes. In a whole bunch of words, read the mid fi comparison above.I find that the x2 is better than the he400 in every way IMO. The only trump card that the 400 is that luscious planar sub bass. But the mids are off and the treble is spikey for sure. And yes I do know that there are mods are EQ to fix that ( please check the OP to the he400 thread ).
The x2 has the complete package and is an audiophile's hp. The price to performance ratio is impressive.
