Tangster
- Mar 28, 2012
Located in Liverpool huh? I might go pick some up after lectures tomorrow.
Still can't get consistently sized letters freehand.
I wonder if u guys have any tips on how to fix an issue im having with my mechanical pencil, ie the lead wont advance if i put the lead in the led tube. If i stick lead in through the tip, it will advance all of the lead on that single piece and then not advance anymore of the lead inside the lead tube. I am sad that my rotring 800 isnt working =(
I want to pick up a converter for my everyday pen, a Cross Century, anyone know of some decent ones? The one I found on amazon has bad reviews and I'm too far from my local pen store to buy one there(115 miles away). Some reasonably priced ink recommendations would be nice as well, preferably under the £10/50ml mark.
I think Akkerman could count as well than
Ah, but the concept of aesthetics in Japan is seen as an integral part of daily life. Both the Iroshizuku inks and the bottles they're in is something to behold.
Ok, my search for a good affordable everyday use pen and writing paper continues.
For paper, I went looking for rhodia/clairefontaine, but ended up with the Maruman Mnemosyne (B5, Spiral Bound, 80 sheets). I also found the Maruman Giuris, but I'm guessing its thicker because its pretty expensive (~$12 for B5, 100 sheets, folder extra.).
The paper is really smooth, thick enough, and there's no ink bleeding on the other side. I'd say worth the $8.
As for pens, I got the Parker IM (Gold + Black) for $25.
Really like the classic look, and its pretty hefty to hold.
Also got the Pilot Prera (Ivory), and Pilot Metropolitan (Black dots). I'm really puzzled as to why the Prera is ~$50, while the Metropolitan is ~$20.
The Prera comes with a cartridge, I'll have to get the convertor separately.
