gopanthersgo1
- Mar 10, 2012
Nada, Spongebob - Battle for Bikini Bottom.Ratchet & Clank?
Isn't mad catz making a new rat with replaceable sensors? I'd wait for that.i plan on buying a RAT7 from mad catz and a steel series qck mouse pad, anyone has any thoughts on this?
i have need of a perfect customizable mouse for my hand, and i already had RAT9 from 2010 to 2012, sold it because of batterries.
my actual A4tech x7 makes problems with wifi signal, so i have to change it.
anyone has a better ideea of a customizable mouse, and an under 10$ mouse pad that would be better than steel series qck?
Yes I honestly feel like having an ultra cool 90000000000000000000000 dpi mouse with some fancy sensor is about equal to having $100 anti vibration feet on an amp. Difference is negligible.
i would not need great senzors or something, i am really going to use it for internet browsing and office/buisness working, but like the ergonomic dessign.
the new rat x pro looks too green and plastic, i need only ergonomic modulation, not senzor, i am not using it for gaming, i am going to use it at a low dpi setting and will not see a difference.
Also, the problem with the senzor should had been solved in 2012, when they added a new version of their rat generations. i had bought my rat9 buggy version before this happened..
Another misconception is dpi = 'speed' your cursor moves.
This is mainly due to Windows software as a ratio value that produces such effects.
Having that ratio value as low as possible while having DPI as high as possible allows for extremely precise movements. Or a more 'lack' of those moments when it seems like it can't round or do very very small movements as your hand is moving.
