- Apr 9, 2011
Huh... Interesting to see a thread for PC Enthusiasts.
Here are my specs:
CPU: Intel Core i5-3570K @ 3.4gHz (easily OC to 4.4gHz, stable)
CPU Cooler: Cooler Master Seidon 240M
RAM: g.Skill Ripjaw Series DDR3-1600 4GBx4
Motherboard: ASRock Z77 Extreme4
GPU: Asus OCII GTX 760
SSDs: 2x240GB
HDDs: Too many to count.
Disk Drive: Blu-Ray/DVD combo drive with burning capabilities
Sound Card: Turtle Beach Montego DDL
PSU: EVGA SuperNova 1000W G2
Peripherals are unimportant right now. Haha.
All packed into a Fractal Design XL R2 case with a few extra ultra-silent fans packed in.
On the topic of the cases. My first was an NZXT Tempest EVO, second was an Antec 900, third being the XL R2. As I went along I started to realize how obnoxious the lights were, though I did do some colour coordination as it evolved. I went with Blue/White in the second case with my mobo for that case actually having a red LED on it that I didn't know about until I turned it on... I liked it enough to stick with it.
Now I'm on a solid black case and actually went with a new PSU altogether so that it didn't have an LED on top of giving me the ability to handle dual GPUs stable.
*Eaglescreech.flac
You forgot something so I FTFY
not bad specs
I don't see the CM Seidon's often.
You have a large PSU that seems overly large for your needs. The typical HDD doesn't go over 10W each at full read/write and these are at the slightly higher end of power usage and non-green models.
For your needs, it seems a much more inexpensive 750W could have suited you considering your GPU consumes at max 160W of which on a 12V rail would be about 13A of which any PSU could easilly push.
Hell, depending on how many HDDs you have. A very very efficent and good 550W could just about handle it. A bit close for comfort obviously but very very good 550W units can easilly do over 100% load for periods. And I doubt you will ever max out everything at the same time.....maxing out your CPU and GPU at full throttle, and same with the HDDs and SSDs.
