I too lost the filter ends. About the only major fault with these wonderful IEMs. I was worried about that wide open tube going straight down to the speaker cone. It was a disaster waiting to happen. Then I discovered that the sticky filter ends that come with the RE0s are a perfect answer. They are a perfect fit and stick beautifully. Hope that helps. I'm fairly sure you can get then from the RE0 site.
They are the things. I would expect them to be sent OKI if ordered - I have found Head-Direct to be efficient. Incidently the tips are the ones I am using with my Panny - and they work extremely well for me.
Yes, those really long HeaDirect biflanges work really well with these. Overall I think that tip/filter bundle is good for HJE900s users, even though it's pricy for what it is.
Also, does anyone experience a lot of driver flex with these?
You know.... I've had my HJE900s for about 7 months now.... and I still have the filters... Do they really come off as easily as people claim? Because I really change tips often, trying to find the right ones... I might buy that RE package so that I have spare filters and some new tips to play around with.
