Oriolus Hybrid IEM
- Thread starter rookie2009
- Tags
- ibasso
zepmaj
- Feb 11, 2017
I pulled the trigger for DM6, preordered it from aliexpress. It was cheaper than Finschi.Yes DM6 is far superior on tunning, handling and amooth transition at woukd I call boundary.
The Finshi feels like a step down on a pure sound basis. Meaning I just felt tgaf everything was less.
Disclaimer, not saying the Finshi does not do its job, is just I was comparing with what I had.
are you ref to https://penonaudio.com/bgvp-dm6.html ?I pulled the trigger for DM6, preordered it from aliexpress. It was cheaper than Finschi.
zepmaj
- Feb 11, 2017
Nope. Aliexpress which is only option in my country, it is $150 until 11.11.are you ref to https://penonaudio.com/bgvp-dm6.html ?
ok, I meant the IEM. Are you ref to that IEM, doesn't matter from where..Nope. Aliexpress which is only option in my country, it is $150 until 11.11.
zepmaj
- Feb 11, 2017
Oh, sorry. Yes.ok, I meant the IEM. Are you ref to that IEM, doesn't matter from where..
littleaboutiem
Would the spinfit cp100 be good for the Finschi?
Edit: as in are they better than stock tips?
- Sep 28, 2016
Nope. Get the spiral dots or the acoustune aet07Would the spinfit cp100 be good for the Finschi?
littleaboutiem
Alright thanks for the tips!
- Sep 28, 2016
Hehe pun intended?Alright thanks for the tips!
littleaboutiem
I tried lmaoHehe pun intended?
thefallenangelx
i am still uncertain on which one i like more: Oriolus Finschi or BGVP DM6...
Probably bass are better on Finschi...
need to get a more in-depth listen to both.
thefallenangelx
Do you own both?Yes DM6 is far superior on tunning, handling and amooth transition at woukd I call boundary.
Could you make a direct more in-depth comparison (mean simple high, bass, sub-bass, mids, soundstage) of the Finschi vs DM6?
I kept the DM6. Sold the other one. What I can say is what someone else said in one of the replies. Going back to Finshi felt like ,giving up on everything.Do you own both?
But to be fair when you remind yourself of the configuration of each, then is not a surprise.
The Finshi overall is fine as a starter, it handles everything Ok, what comes to mind is "light", almost like I never had a good seal. However I did and you also had to crank up the volume a lot more. If you're looking for a powerful sound signature at all regions I would focus on the dm6.
