Oriolus Hybrid IEM
Oct 15, 2018 at 4:31 AM Post #1,352 of 1,871
Spiral dots (smooth and natural)
Final type E ( sharper more neutral)
Can you post link for purchase?
I believe the stock foam are not so good, anybody tried the stock looks like double flange "spinfit"?
I just purchased also the Symbio W (ex mandarines), hope they are good!
Oct 15, 2018 at 7:39 AM Post #1,355 of 1,871
Any reccomandation on which tips/cable to use with the Finschi?
Tried several tips with Finschi. Best so far is Spinfit CP240. Regarding cables, using a $20 Amazon **** balanced cable which works great (just because I want something balanced and flexible).
Oct 15, 2018 at 8:10 AM Post #1,356 of 1,871
link to the cable?
Oct 15, 2018 at 8:21 AM Post #1,357 of 1,871
Oct 15, 2018 at 8:19 PM Post #1,359 of 1,871
After my visit to SG, I had a chance to try a large variety of product in various shops and thanks to the amazing local talent living in Singapore with their amazing setup, trying so many exotic setups not found in shops.
Among the products that stood out the most for me was the Oriolus Mellianus and the old Sony PCM D1 recorder. In terms of overall built quality, Mellianus is flawless, and in terms of sound let'sts just say it gives you detail without sounding fatiguing, it gives you bass without sounding thick and it gives you soundstage without losing intimacy. It is my cup of tea, and beside my ACS Emotion, they are the two BA IEM I currently only care of owning.
The only issue is the stiff cable and fit can be a bit tricky. I went to SG to place an order for a FitEar MH335DW, which still an amazing product, however all I can think about now is Mellianus.
Just stumbled on this the other day, they're Mellianus custom fit. Don't know whether they're made by Oriolus or a 3rd party, or is it legit.
Anyway here's the original link in Japanese, you should check it out:
https://www.phileweb.com/news/photo/d-av/453/45310/cusom_thumb.jpg
Oct 16, 2018 at 1:29 PM Post #1,361 of 1,871
Hey guys, want to get the Finschi but I heard that the Finschi has some issue with driver flex. Just wanted to know if everyone here has the same problem or are they just isolated cases?
Also, would you guys recommend me the Comets or Finschi? My playlist is like 70% electronic music, but I do listen to J-pop, rock and sometimes indie too.
Thanks in advance!
Oct 16, 2018 at 1:47 PM Post #1,362 of 1,871
Thanks in advance!
I've had no issues with driver flex. Had a lot with Bravado, but flex has no effect on sound or reliability.
Oct 17, 2018 at 5:50 AM Post #1,364 of 1,871
Thanks! Is the Finschi a good choice for me do you think?
I can't see why you wouldn't be happy with it. It offers a lot for in this hobby a little money. I've had Sony ex1000 EE Bravado and Campfire Andromeda twice and i'm happy with the Finschi. Not saying it's better than or equal to Andromeda in any way! Andromeda fit in my right ear just didn't work. I'm looking forward to Campfires new release at the end of the month and hopefully a better fit. If you want to skip all of this trying out different IEMs grab the Andromeda and a Sony 300 ZX and delete your account and don't look back
