1TrickPony
anyone know what the default eartips are? I seem to have lost mine.
Grey Foams. I'd recommend the 1$ ones from Penon Audio. There's also the complys
That was my favorite combination on the FLC8S. If they are a better version of that, I may just go with those....andromeda is pretty close to flc8s on gold grey red, with slightly more bass (especially subbass) and better technicalities. didnt have long time to audition both though, so cant give a better comparison
Is that a brand?
I managed to take the filter out on the left side and place it back in (was a huge pain), but I completely lost the right filter inside the IEM...
Surprisingly, it sounds the exact same (I was being paranoid before), so I don't think it affected the sound quality at all. I still regret cleaning the ports though...
Bought these used unfortunately. I emailed the Oriolus team, and they told me not to worry about it.Maybe could bring back to your local distributor to check if they could help to remove the right filter?
Guess it is just meant to block dirt or water from entering yet allowing air to pass for the bass to work, so should not have any impact on sound.
do you have more photos, i'm curious to see what the insides look like.
Man. There's something really special with the v2: regardless whatever dap I'm using, these really play well with many daps in collection.
Opus#1 brings out the soundstage.
Oriolus Dp100 dap seduces you with its mids.
Shanling M3 being more analytic brings out better timbre, combining with the smooth sound of the V2.
Anyone else use any "analytical" daps with these?
Opus #2 here.. the pairing is mind blowing due to analytical and musical at the same time...Man. There's something really special with the v2: regardless whatever dap I'm using, these really play well with many daps in collection.
