gerelmx1986
Order status update yay! approved ready for fullfillment
So you're saying that if you had a Schiit Ragnarok that would be able to cover any headphone for any music genre in terms of power output and assuming it has a low output impedance for multiple balanced armature in-ear earphones and a sufficient slew rate for even 24/192 music, but it sounds bad to you with a particular set of headphones that your headphones wouldn't be "driven" well?
That sounds more like synergy than anything. There would be no logical explanation to say that the headphones wouldn't be "driven" well providing that the Ragnarok is pretty much overkill for headphones.
So I plan to return the Sony PHA-1A because of the brutal treble and go for the Oppo HA-2. I have a iPod Classic 7th Generation and plan to pair it with it. My other questions are will the HA-2 be able to handle my Beyerdynamic DT-770 Pro 250 Ohms? Also how is the bass boost of the HA-2? I listen to my iPod Classic with EQ off so I'm hoping the bass boost will give me a clean thump. Also is this a bright dac and amp?
Well, the HA-2 is about 2,5 times more powerful in comparison and it is definitely brighter than the pha-1A
I was hoping it wasn't bright.
they say the bass boost is a bit muddy overpowering?, really don't know as mine was shipped today, too son to tell
I haven't heard that yet, but maybe depending on what you're driving? The bass on the xba-z5 is very detailed out of the ha-2.
I find the ha-2 to be more bright than warm, but in general it's a pretty neutral sounding amp. The bass boost is very clean.
High gain should be able to drive the 770 pro 250s decently, but I wouldn't be surprised if you end up listening at close to max volume - I strap a Cayin C5 to the top of the ha-2 when I want to drive full size cans.
I definitely don't use the bass boost on the HA-2 w/ my PM-3s...just a muddy mess for the most part. Straight out of the amp with no adjustments is so much nicer. I also don't think it's an especially bright amp, but that's more headphone dependent IMO.
