Yes, I do listen at fairly loud levels (shorter periods of time mind you). My main concern/point is that any amplifier starts to perform to it's lowest ability level once it is pushed to the max, and certainly over prolonged periods of time. So to me yes, you can use the E12 for instance to drive the 560s, but it will not be at it's best when you have it turned all the way up, I don't think that is a controversial position to take. So again, if you like to have moderate to loud playback volume, and you listen to very demanding music (consistent high amplitude, little dynamic range) the amp at max or close to max is not going to perform as well as circuitry spec'd to have headroom left over. My E12 is about 1.5 years old, so the generation with the newer bass boost (not that I use bass boost myself).
