Subhakar
- Nov 26, 2015
Thank you, guys. May be you could list some headphones that could be reasonable to listen to with the amp? The thing is my local store doesn't has wide range of headphones so I have to give them a list of models so they order them into the store where I could listen to. Or that could be a general guidance, the only constraints I can think of is that they should be under $500 amount. May be OPPO pm-3? I heard that they sounds really good with the amp...
Sure, Oppo PM3 is a great match and synergy with HA-2 and terrific value-for-money.
You may want to read up on these too:
http://headfonics.com/2015/12/the-wizard-savant-iem-by-noble-audio/ (IEM,though)
http://www.amazon.com/PLAY-BANG-OLUFSEN-Wireless-Headphones/dp/B00R45Z2WU/ref=sr_1_1?srs=8415441011&ie=UTF8&qid=1456848093&sr=8-1&keywords=b%26o
http://www.amazon.com/Earsonics--Velvet-Premium-Signature-Headphones/dp/B00XAYQ5AC/ref=lp_8415441011_1_4?srs=8415441011&ie=UTF8&qid=1456848065&sr=8-4
http://www.amazon.com/dp/B00MULH672?psc=1
http://www.amazon.com/Sennheiser-HD-650-Professional-Headphone/dp/B00018MSNI/ref=pd_sim_267_15?ie=UTF8&dpID=41yMJKBvOVL&dpSrc=sims&preST=_AC_UL160_SR114%2C160_&refRID=0Y5HZYG3NHJCE9CAVG1Y
http://www.amazon.com/beyerdynamic-DT-1770-PRO-Headphones/dp/B0142FEWD4/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1456848361&sr=1-1&keywords=dt+1770
http://www.amazon.com/gp/product/B00F6PRSMW/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687742&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B003IHUHGE&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=19FBX7C7ZZRE1H1T2Q4C
http://www.amazon.com/Shure-SRH1540-Premium-Closed-Back-Headphones/dp/B00FR8DMR8/ref=pd_sim_267_5?ie=UTF8&dpID=41NKHw1eAYL&dpSrc=sims&preST=_AC_UL160_SR92%2C160_&refRID=0QG0TY45K51Z9M4CN3G0
Or, wait for the next Massdrop drop of:
https://www.massdrop.com/buy/fostex-x-massdrop-th-x00/talk/357035
or
https://www.massdrop.com/vote/Closed-Over-Ear-Headphones
Or, the new DUNU 4-BA thingy that is going to be launched next month or later...
