Donie Ray Samba-an
Just installed iOS 10.3.3. No dropouts yet, knock on wood!
Until now no dropouts? Are you using USB camera kit 3?
If it's on iOS, wouldn't it make more sense to post here?
https://discussions.apple.com/thread/7932507?start=0&tstart=0
I tried with ios 10.3.3 and a dragonfly red with the usb 3 cck and i was getting the glitches . its better than it was but still annoying.Interestingly, while there seems to be (near?) universal consensus on this Board that the problem is completely solved in 10.3,3, there are a number of reports on the Apple thread (referenced above) of "glitches," which I interpret as momentary interruptions in the music, that have replaced the complete dropouts. Is anybody experiencing those?
(Still holding on to 10.2.1)
EDIT:I tried with my chord mojo and got the same glitching. However, I powered off my phone completely and powered it back on again then tried the mojo again. i've listened for 30 minutes without any glitches. before the reboot it was happening every few minutes so rebooting the phone seems to have made a big difference. YMMV
Hi, I just tried again with the dragonfly red and it has worked fine for more than 30 minutes with no glitches. The initial reboot before the mojo seems to have stopped all the glitches under 10.3.3 - regardless of whether I use the dfr or mojo.Did you try the rebooting procedure with your DFR? Did it work ( no glitches???
I'm on android and love it. However, most android devices resample the source material to 48 or 96K, even usb audio out. Not a deal breaker, but also not ideal. Apple at least put out 44.1 to my external DAC...before 10.3 that is.Apple becomes a better and better company it seems... It's time to switch to Android I guess...
