Oppo HA-1 Impressions Thread
post-10795710
Post #1,441 of 5,289
JML
Another positive review:  http://www.cnet.com/news/the-oppo-ha-1-headphone-amplifier-definitely-a-slam-dunk-for-audiophiles/#ftag=rss.audiophiliac.ftag
post-10795722
Post #1,442 of 5,289
SpudHarris
I am sure this has been discussed before but for the life of me I can not find an answer.
Everything I play through the HA1 shows as one step above. 16bit shows as 24bit and 24bit shows as 32bit. Any ideas?? I am feeding the HA1 via USB from a ZEN Music player..
Thanks guys in advance.
post-10795756
Post #1,443 of 5,289
rick216
How does this compare to the top of the line Burson Audio Conductor?
post-10796670
Post #1,444 of 5,289
  This is a question for OPPO / HasturTheYellow : What is the impedance of the single-ended and balanced outputs on the back of the HA-1 unit. I am considering using a passive pre-amp for volume control in between the OPPO and a power amplifier and would like to take the HA-1's output impedance values into account.
I don't have any specific impedance measurements, but as I recall the BDP-95 had an output impedance of 300 ohm. I would expect something similar from the HA-1.
I'll try to get numbers for you tomorrow, but I will make no guarantees, as last timed I had asked for discrete numbers I was not provided any. We usually just tell customers that they should use the BDP9x/10x and HA-1 products with devices that have an input impedance between 10K and 40K, but the player will work all the way down to 1K input impedance.
post-10796675
Post #1,445 of 5,289
  Hi, guys. I have some problems with my setup. I have my Retina MacBook Pro hooked to the HA-1 via USB cable (5 meters), the headphones are HD800s. There's something wrong with the sound on Mac OS X. First, I thought that the USB cable is the problem, but it's not. The problems are gone when I boot into Windows 8.1 via BootCamp. On Mac OS X there are "pops" and "cracks" in the sound. Are my settings wrong?
5m may be too long, even if it works properly in Window 8.1. We do not recommend cables which are longer than 12' in length.
Have you tried a shorter cable, like a 6' USB cable that came with a USB printer?
post-10796876
Post #1,446 of 5,289
murrays
My question is, where do you get a converter from the 4-pin XLR balanced headphone output to two 3-pin XLR balanced outputs that could feed a power amp? Also, how would this even work? You need a total of six connections for a balanced stereo power amp:
Left: V+ / Gnd / V-
Right: V+ / Gnd / V-
The 4-pin XLR balanced headphone out only offers:
Left: V+ / V-
Right: V+ / V-
So how would a converter cable even work (i.e., where is the Gnd connection coming from)? I've heard of 5-pin XLR which carries a ground pin and can be split into two 3-pin XLRs via a Y cable. But how in the world do you go from 4-pin XLR into two 3-pin XLR, there just aren't enough pins?
The whole point of balanced signals is that they are not referenced to ground.
Each signal is carried by a pair of + and - voltages to cancel out common mode noise.
The earth is only required for a screen shield and should connected at the one correct end only (to avoid hum loops).
So, you should be able to construct a minimal stereo balanced adapter with 4 wires.
post-10797191
Post #1,447 of 5,289
Scarfin
This seems to be the problem, after all. I tried to change my graphics card settings from my Retina MacBook Pro but this didn't solve the popping and crackling of the sound. Unfortunately I don't have a shorter USB A-B cable atm so I can't test that.
I'd rather not buy a shorter USB cable, anyway, because it would make things too complicated with my setup. My HA-1 is not close enough my MacBook and computer desk + my TV set is right next to the HA-1 (and my PlayStation 4 hooked via 1.5 meter optical cable). With a shorter USB cable, I'd have to change the whole setup and buy a longer optical cable, too.
So, would an active USB hub solve this audio problem? Could it remove the popping and crackling of the sound with the 5 meter USB cable? JML, what kind of a USB hub do you have?
Sorry about the off-topic conversation.
post-10797229
Post #1,448 of 5,289
JML
Can you temporarily set up the HA-1 close to your computer, and just buy a shorter cable to test it out?  If that works, then at least you know it's the cable or the cable length.  Reading the USB spec explanation, the length limitation is due to the delay in the signals carried by the cable, and that may be the cause and not the AC power that a hub would augment.  A good inexpensive USB cable would be the Belkin Gold Series, which is only available in two sizes, 6 and 10 feet.
post-10797238
Post #1,449 of 5,289
SpudHarris
Anyone have experience of this??
post-10797466
Post #1,451 of 5,289
SpudHarris
Hi Mike, I only have the Zen as a USB source.
I unplugged Zen + iUSB etc.. and checked/unchecked the ''play DSD over PCM'' and everything seems to be back to normal (for now). Strange.... I think it may be a glitch within the Logitech settings.
post-10797769
Post #1,452 of 5,289
SharpEars
The lower the output impedance, the better. If the HA-1 truly has a 300 ohm output impedance on its rear XLR balanced outputs, that would be awesome!
post-10797802
Post #1,453 of 5,289
Scarfin
I bought a 1.8 meter USB cable and the popping and crackling seems to be gone! Thanks for the help, everyone!
post-10797823
Post #1,454 of 5,289
BobJS
Dayton, OH
Dayton, OH
As a previous poster asked, I'm also interested in a comparison with the Burson Conductor.  I'm interested in going balanced and wanted to try to get some assurances (hah!) that I wouldn't be disappointed coming from the Burson.
post-10798456
Post #1,455 of 5,289
madmalkav
I was considering to buy it in the next months, but price in Europe seems to rise from $1200 to €1500. That is a whopping $2000 , or a 66% price increase, so I will be interested in your opinion if it is still worthy or I will be better with other options.
