Headphone Amplifier Performance Specifications
Specification Condition XLR Input - Balanced Output RCA Input - 6.35 mm Output
Maximum Output Power (Per Channel) Into 600 Ohm 2400 mW 600 mW
Into 32 Ohm 3000 mW 3500 mW
Rated Output Power
(Per Channel) Into 600 Ohm 800 mW 200 mW
Into 32 Ohm 2000 mW 500 mW
Frequency Response 10 Hz – 200 kHz (+0/-1 dB)
20 Hz – 20 kHz (+0/-0.04 dB) 10 Hz – 200 kHz (+0/-1 dB)
THD+N at 1k Hz
(A Weight, 20 Hz – 20 kHz) Rated Power < 0.0018% (< -95 dB) < 0.0056% (< -85 dB)
50 mW < 0.001% (< -100 dB) < 0.0022% (< -93dB)
Channel Separation > 120 dB > 90 dB
Signal-to-Noise Ratio
(A Weight, 20 Hz – 20 kHz) > 111 dB > 111 dB
Dynamic Range
(1 kHz -60 dB, A Weight, 20 Hz – 20 kHz) > 120 dB > 115 dB
Output Impedance 0.5 Ohm 0.7 Ohm
(Test condition: Volume knob at Max position and an input signal to drive the output with 600 Ohm loads to the rated output power, unless otherwise noted.)
"Made for iPod", "Made for iPhone", and "Made for iPad" mean that an electronic accessory has been designed to connect specifically to iPod® , iPhone®, or iPad®, respectively, and has been certified by the developer to meet Apple performance standards. Apple is not responsible for the operation of this device or its compliance with safety and regulatory standards. Please note that the use of this accessory with iPod, iPhone, or iPad may affect wireless performance.
iPad, iPhone, iPod and iPod touch® are trademarks of Apple Inc., registered in the U.S. and other countries.
Compatible iPod/iPhone/iPad Models
- USB works with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPad (4th generation), iPad mini, iPod touch (5th generation).
- Bluetooth technology works with iPhone 5S, iPhone 5C, iPhone 5, iPhone 4S, iPad (4th generation), iPad mini, and iPod touch (5th generation).
All trademarks are the property of their respective owners.
