Megalith
- Feb 17, 2009
So it sounds like the HA-1 will output everything you throw at it untouched and not upsample everything like my current DAC. That's what I wanted to hear.
Turns out that it was a YouTube thing; that seems to be limited to 16-bit output. For some reason I thought everything in Windows that wasn't running through WASAPI or ASIO would go by whatever was set in the control panel.
So far, I've found two annoying things with the Oppo, both involving mute. One, I can't believe there isn't a mute button on the unit itself; basic functions should never be limited to the remote. Second, the HA-1 lets you mute the pre-amp section but I wish you could also do the opposite and only mute the headphone section for whenever you are using it strictly as a preamp. I am pretty sure I can hear the output of my open headphones even as my active monitors are playing. Sure, I could unplug my headphones constantly, but I'm not sure if that would wear down the XLR connector in any way.
Hi, someone with HA-1 + Sony ZX2 ?
I would like to read some impression in general and overall on the best way to link them
Because, at least for me, it isn't easy to find digital connection output cables for Z2.
I'm tempted by Oppo....
Thanks
depends on where the volume knob is at... try it with the knob fully on... then try it with the knob fully off... you'll find the answer pretty quick....
I'm on page 23 of the 269 page thread.
I'm trying to decide between the Oppo, and the MJOLNIR 2 with my Musical Fidelity M1 (eventually upgrading to the GUNGNIR DAC). There is a price difference of course. Using HD-650, HE-560, 400i, and occasionally B&W P7. I'm looking toward an end game kind of rig (if that is possible)
The tubes and SS possibilities of the MJOLNIR 2 do intrigue me. But the all in one beauty of the Oppo with all of its features look good too.
