I visited another thread on the forum
http://www.head-fi.org/t/736294/gustard-u12-usb-interface-8-core-xmos-chip
It is a thread on a USB-SPDIF interface. It is a great thread for information on some of the issues the plauges the digital interfaces. I made some inquires about upgrading the clock chips of the Oppo, and that is not just straight forward.
As for the construction of the Oppo, it appears to be well designed on the digital interface. The components generating the clocks, are unknown in accuracy, and they matter a lot. If anyone has a name for me, to someone that might be trusted to upgrade the clock chips for me, please let med know. PM would be great.
On the topic of the getting the Gustard U12, it mainly is the topic if the power supply on the Oppo is weak compared the the Gustard, and the accuracy of the clock generators in both. And as always, shielding.
Given what it takes to generate a high quality SPDIF signal, in particular the accuracy as in low jitter, the onboard SPDIF of a computer simply fails. This is easier to correct to high end audio needs, by using USB. But USB comes at a price of a lot of included noise, on top of the USB signal. More so than SPDIF. Or at least, that is my break down of the issue so far.
The quality of the optical transmission from a PC, is plagued by the interfaces generating the optical signals, as they lack accuracy.
So in short
- The signal survives the transmission intact. It probably will decode into the same stream.
- The signal is degregated by the digital interface. In particular jitter is an issue, as in the accuracy of the signal.
- Noise is added on top of signal, and that noise influence the receiving end.
Please do not get stuck in point one only.
For the Oppo, a good USB cable can help. It helped me a lot. That was the Coffee of Audioquest. If anyone tries something, it would be nice to hear if it works.
I will let you know, what I try out, and if it helped in any way.
