Looks good to me.Looks a bit uneven, plus i don't think that this stencil is edited to fit the 3.5mm jack plug. also i still need to cover the ball joint space, coz i think there's gonna be leaking from there.
Also a quesiton, if there's a loctite on the plug thread, should i also add silicon on the inner cup side, where the plug is connected?
To seal the holes i´ve used some putty (Blu Tack, Patafix). Works great and can be removed easily.
