Here is the Google Drive link:
https://drive.google.com/file/d/1kScGyVaThyFx2b29cEEebaVCFZkktkKv/view?usp=sharing
Do note that these measurements are before some modifications I did to my pair. The modification that made the greatest impact on the sound was including the little foam gasket between the driver and the mounting plate that came with my stock t50rp. Another significant modification was re positioning my alpha pads to have the vertical side of the "ear rectangle" align parallel with the connector port. I also removed the tiny white felt on the back of the mk3 driver. If I remember correctly, the suggestion I received from Dan was to add some felt on the back of the driver to try to even out the midrange.
On another note, I currently plan on reprinting my cups to fit 2.5 mm connectors, as my current cups with the HR connectors are damaged.
@musicfan145 , on your post here:
https://www.head-fi.org/threads/ope...-from-mrspeakers.825868/page-22#post-13292084 you modified the cups to increase its structural stability and to include 2.5mm connectors. May you post them through something like thingverse or dropbox? It appears that after the new makeover of Headfi only users of a certain rank may access linked attachments to posts.
Also, may someone recommend a relatively cheap and good y cable with 2.5mm on the two ends and 3.5mm on the main end for my new pair of alphas? Thanks
