linux4ever
Hey Guys.
If Onkyo DP-X1 didn't exist, What would be your next go to DAP?
Just curious
Cayin I5 or opus #1
Hey Guys.
Just curious
any of you guys use the line out on your DPX1 to play music through your home system? line out any good?
I'm actually heavily leaning towards an AK70 and the occasional Mojo stack. I like the smaller size. I just wish I could find the true specs of the output of the AK70.
Hey Guys.
Just curious
Ak70 output Power = ak380. But what I hear ak70 is quite bassy and its dac cannot match the ESS Sabre
Hi Guys, If the Line Out Mode is enabled, does the DP-X1 has a balanced output on its 2.5mm TRRS? or just on the 3.5mm TRS?
I'm planning to connect the 2.5mm balanced output of the DP-X1 to the balanced mini 4-pin input of AlgoRhythm Duet.
Yes, the single-ended (3.5mm TRS) output can be switched between Line Out, and "Amp" out to drive headphones.
I believe that the Line Output is available only on the 3.5mm TRS Single-Ended jack.
That stinks and is a missed opportunity! It'd be fantastic if we could pump the Balanced H/O into a Balanced amp for more power.
I guess after having mine for 9 months or so ,just find the battery life terrible,Just not sure what else comes closes ticking all the boxes like Onkyo
