All 3rd party apps "should" be going through the DACs as stated recently. I just updated my poweramp to a beta that is suppose to not resample, I have not tried it yet. UAPP is suppose to not upsample with the latest update, again have not tried it yet.
UAPP does not resample only if you have connected an external DAC via USB. Otherwise it sends audio data to Android which is fixed at 48Khz but that still goes to the DAC.
Would like to seek the help of android experts here, i'm trying to install the walkman app from sony but their latest walkman app is now named "music" and i think this is the main reason i cannot install it (was able to get an apk and it installs on other android devices) since onkyo's music player is also named "music". I tried getting the old version still named "walkman" and it did install, but this is early 2016 build and they have added more enhancements since then... was wondering if there is a way to sort of rename the "walkman (music)" apk ... thanks in advance
Looking for some hints about managing the music on my DP-X1.
I'm currently using JRiver Media Center 22, to rip and/or convert music to FLAC files, to put on my DAPs.
So far, I've just done a copy > paste in Windows Explorer, to move the folders & files from the PC, to the DP-X1 and M1.
Windows pops-up a Warning box, every time I go to copy FLAC files, asking if I want to convert to another format.
I'd like to use a method (command line, like Robocopy; or program like JRiver or X-DAP) that is configurable to copy only the new folders & files to the DAPs, and possibly be able to exclude some folders & files from being transferred (but not delete them from the PC, like a Sync command might do). One caveat - the DP-X1 does not show up as a mounted drive letter on the PC (like the M1 does), so I haven't figured out how Robocopy would access the SD Cards in the DP-X1...
So, what do you use to manage the music transfers to your DAPs?
Is your DP-X1 rooted, or not?
All of my Android devices (including DP-X1) are rooted, but I suspect you could install a file manager app, and rename the walkman app file, before you install it. But, if they have any hard-coded references in the app, to the app folder name, then it probably won't work correctly.
^its not rooted sir, my other android devices are rooted but have not done it to the dpx1, just got it and i dont want to lose its warranty, at least for now hehe just wanted to use the walkman app from time to time
Just like with most phones you can just restore the firmware to stock in case You have to take your device to authorised service, If root doesn't require unlocking bootloader (which is exactly the case on X1) then there is no way anyone will be able to tell that you rooted your device in the past.
I use DRF in UAPP with hardware volume to max and with a 1/3 of the volume software my HE-400i litterally screams... Meanwile with dpx1 in balanced mode with the same headphones they simply sound... (high gain)... I don't understand.... with my Edition X the difference is less due the more sensivity of the Headphones... but i suppose is the same kind of difference... The DRF output volume is more strong even of my desktop amplifier Hifiman EF2c (320 mW X 2)... I don't understand...
Now I purchase one iFi iCAn SE for the Onkyo, but i have to lost the balanced connection...
That doesn't make much sense since the DP-X1 in balanced mode should out-power the DRF. You're sure there isn't some form of pre-amp applied in UAPP? You should always use it in bit perfect mode.
