Wolvebain
Do side buttons work properly with 3rd party players like Poweramp or Spotify? Not only play/pause but also prev/next
Haven't tried Spotify, but Tidal, PowerAmp, and Neutron Music Player works with the side buttons.
I believe @addyg is referring to the the Vsonic GR07X.. I used to to own the previous generation version of it, and they were awesome.. great bang for buck.
There's also the Sennheiser IE80 in the USD.200 mark range.. also another IEM I owned and really enjoyed. You'd need a bespoke or boutique 2.5mm balanced cable for them, but they should be cheap on eBay, etc. depending on where you stay.
There's also the triple-driver Westone W30 & Sony MDR7550 that I know of, in that price range.
There are several different versions of Viper4Android that can be downloaded and installed. For V4A specific questions, the various XDA Forums are your best bet for getting answers.
The option to select the quality of the driver is in an older version, but not in v2.5.0.5 (FX) that I have installed on my rooted DP-X1.
v2.5.0.5 (FX) works with any of the media apps that I've got installed, including YouTube.
This is the exact same version I have, it does work with everything but after a reboot I need to start the OEM player to have it working with the rest of it, also I did not install Selina Mode Changer like some old guide recommend, not sure if I should.
Did you have the option to choose the quality of driver during installation?
Besides this, since you got a balanced cable, what type of improvement did you get with it?
Just got back from CanJam NYC where I asked the Onkyo rep if the DP-X1A was going to be released in the US. He said that it was and that he had one with him but was told he could not show it even though they had shown it at other shows. I then asked about availability and he said it would be available in the US next month.
So if anyone in the US wants one, the wait is almost over.
The first version of Viper4Andriod that I tried, was v2.4.0.1, and it did have a diver quality option.
I tried editing some System files, following directions I found on XDA Forums, which was supposed to allow the V4A mediaserver to work, even when SELinux is set to Enforcing. That didn't work. So, I edited the System files which keep SELinux set to Permissive, and that does work. If you don't want to edit the files, you can install one of the SELinux Mode Changers, which needs to be run each time you reboot.
When V4A is running, it will modify the audio output for the Headphones and for Bluetooth. I've never tried streaming Audio to an external DAC, so I don't know whether V4A works on the USB port.
