Since I was curious about the Dual DAC / Dual Amp design of the DP-X1, I recently posted a couple of questions on the Onkyo USA Facebook page -
https://www.facebook.com/OnkyoUSA/posts/10155743980304689?comment_id=10155754772164689
Here are the questions, and replies -
David Baldock - I've got a technical question about a portable audio device.
In the Onkyo DP-X1 and DP-X1A, are the dual DACs and Dual Amplifier strings used when driving earphones from the Single-ended (3.5mm TRS) output? And, when driving earphones from the Balanced (2.5mm TRRS) output, are the dual DACs and Dual Amplifier strings used, when playing music with apps other than Onkyo Play Music? Thanks!
Onkyo USA - Hello David, when using the Onkyo Music APP both amplifiers and DAC's will be active when using the 2.5 or 3.5 output. We are not sure since we have not tested every third party APP but so far only one DAC is active. Thank you, CB
David Baldock - Thanks for the reply!
When I saw this on the product page -
"The DP-X1 has two amps and two digital/analog convertors which allow for extreme power and signal control. The double ESS Sabre ES9018K2M DACs and double ESS Sabre 9601K amps make balanced output possible via 2.5 mm output."
- I envisioned that one DAC & Amplifier would be for the Left Audio channel, and the other DAC & Amplifier would be for the Right Audio channel.
I know I'm hearing stereo audio when listening to third party Apps. So, as an Electronics Technician, I'm curious about this --- Are both DACs actually operating as Stereo devices, so that either one can send Left & Right Audio to the Dual Amplifiers? Thanks again!
Onkyo USA - Hi David, Both channels go through both amplifiers and DAC's. It is not left to one and right to the other. Thank you, CB
Their reply leads me to believe that it's probably necessary for Apps to be specifically written to take advantage of the Dual architecture.
Take Care,
David Baldock
