ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
Jan 16, 2017 at 4:04 PM Post #13,037 of 16,326
Jan 16, 2017 at 6:20 PM Post #13,039 of 16,326
After having some troubles with quick battery drainage I went through the whole settings of the device. Step-by-step. There are a couple of "push" settings included which reduce battery time... seems to be a better now.
However I just received the DP-X1A from Amazon Japan today. Been switching microSDXC cards from the X1 to the X1A comparing the soundstage, the clearity - the feeling it gives me.
To sum it up:
Whatever Onkyo did to the hardware - I like it
1. The X1A form Japan is louder.
Not just a little bit - it gives it a whole new bang and gets way more out of the headphones I'm using (Beyerdynamic DT990 Edition 250 ohms, Beyerdynamic T90 250 ohm, Ultimate Ears Triple.Fi 10 Customfit). This could be due to the stupid EU regulation to max the volume so that people don't get hearing damages (Thank you EU, I can decide on my own how loud I prefer my music).
I will most likely make a short trip to Heilbronn (Germany) to Beyerdynamic and try out the T1.2 (600 ohms) with the balanced 2.5 mm cable that will be provided by Beyer most likely in April.
2. Even though the X1 as well as the X1A have the same battery (1.630 mAh) the X1A will last a couple of hours longer.
This could also be due to a faulty X1 as I've been complaining about battery life from the day I got it,
...BUT: I checked carefully to have exact the same settings, the same apps installed, the same music, the same headphones - it is draining slower - even when downloading TIDAL for offline listening.
3. Not sound-related: CHEAPER!
The X1 currently costs EUR 770 at Amazon.de
The X1A cost me EUR 420 incl. shipping and handling at Amazon.jp.co
That is EUR 350!!! (US $372!!!)
Well, the X1A is a keeper. Will return the X1 to Amazon.de as I'm still in the return period.
Sorry, or the long post - but I just head to write that down to lose the smile in my face... :wink: Haha!
-Dennis
Jan 16, 2017 at 6:44 PM Post #13,040 of 16,326
  here is how to about unlocking your onkyo dp-x1. compiled twrp for our device and here is the guide.
prerequisites - fastboot + fastboot drivers for onkyo dp-x1.
okay, so here we go:
turn off your device.
turn it on holding backward and power buttons
connect it to pc.
in command line do
and then you will see your device connected.
next thing - we verify that bootleader unlocked or not
pay attention to
if it is false - unlock your bootloader by
here is twrp 3.0.2-0 recovery:
https://drive.google.com/file/d/0B9WN-DrZ4uGTa2tCNzRJNHROTmM/view?usp=sharing
md5:
https://drive.google.com/file/d/0B9WN-DrZ4uGTMGJmUmtKTHdwaUU/view?usp=sharing
while you're at the bootloader, you can try to boot to your new twrp recovery by doing
if it is booting and working for you, you can replace stock recovery with it by flashing it from fastboot bootloader by
or by flashing image through twrp itself (available through menu)
WANT ROOT?
Flash SuperSU:
http://download.chainfire.eu/supersu-stable
I jus got my dp- x1A where can I find the driver for it (fastboot + fastboot drivers for onkyo dp-x1) ?
Jan 16, 2017 at 7:48 PM Post #13,041 of 16,326
Jan 16, 2017 at 7:55 PM Post #13,042 of 16,326
Also is it a way to browse the lan and or  my local DNLA server with the stock music Player and so far I can only use the same stock player to play thru the Mojo USB audio.?
how to make it play with HibyMusic since with it I can browse the Lan but no sound thru OTG so far?
Jan 16, 2017 at 8:15 PM Post #13,043 of 16,326
To sum it up:
-Dennis
Thanks for review!
Jan 16, 2017 at 8:20 PM Post #13,044 of 16,326
ES file explorer can browse the LAN.
Jan 16, 2017 at 9:16 PM Post #13,046 of 16,326
-Dennis
The DP-X1A is currently 59,280 = USD$520 on Amazon Japan - https://www.amazon.co.jp/ONKYO-%E3%83%87%E3%82%B8%E3%82%BF%E3%83%AB%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC-DPX1A-B-%E3%83%8F%E3%82%A4%E3%83%AC%E3%82%BE%E5%AF%BE%E5%BF%9C/dp/B01M0XN4KI/ref=sr_1_1?ie=UTF8&qid=1484618624&sr=8-1&keywords=dp-x1a
Jan 16, 2017 at 9:50 PM Post #13,048 of 16,326
Jan 16, 2017 at 10:11 PM Post #13,049 of 16,326
DP-X1 is going for a loooow price now on Amazon JP. Anyone bought one of there recently? Is the loose jack thing still an issue or is that a thing of the past now.
PS: I know this issue has been discussed a gazillion times, but I thought better to get a latest update on the topic
