Some random observations from a new DP-X1 owner...I'm sure most of this has been discussed somewhere in this very long thread already, but I'm only through reading the first 150 pages of posts...
-First of all, I really like the sound. It is an improvement over my AK100ii...hard to quantify, but the balanced out sounds sublime! I'm using a balanced cable to Shure SE846s, with custom Sensaphonic sleeves. I'm also using a balanced cable to my Violectric V281 amp and output via a balanced cable to HiFiMan HE1000s at home.
-I was concerned about connecting the DP-X1 via a balanced cable to the 3-pin XLR inputs on my V281 amp (vs. headphones) because there is no ground in the balanced cable. The DP-X1 manual only addresses using the balanced out when connecting to headphones, not a headphone amp. The AK100ii manual says to use a special adapter that uses the 2.5mm and 3.5mm jacks simultaneously when connecting to equipment other than headphones, so you are connecting ground via the 3.5mm jack. The DP-X1 manual specifically says not to use both jacks simultaneously. There are only a few cables with the special adapter for the AK100ii and they are super expensive. Long story short, I bought a 2.5mm to 3-pin XLR cable from Surf Cables and it works perfectly, without a ground! I contacted Surf Cables before connecting and they said they get this question a lot, and they've never heard of a problem doing it this way.
-The HE1000s sound incredible connected via balanced through my V281. I have yet to try the balanced out from the DP-X1 directly to the HE1000s to see if it can drive the headphones adequately without a separate headphone amp, but I do have a cable on the way to try this.
-Since the DP-X1 has "MQA," I decided to try this. I went to the 2L Nordic Sound website "HiRes Test Bench" page and downloaded all of the sample files! The MQA files sound great! I have a hard time telling much difference between the much smaller MQA file and the much larger DSD files. Anyway, I highly recommend going to 2L and check it out yourself! Since Tidal is supposed to start streaming MQA quality early next year, I'm very encouraged by this.
-Headphone jacks...might as well comment on this...my first unit had a loose 2.5mm jack. So does my second. By loose, I mean there is a small amount of play side to side. My first unit was "Used-Like New" from Amazon, and it also had a 3.5mm jack that barely had enough grab to hold the plug in place. So I guess there are two types of potential issues with jacks. I'm not going to worry about it further. If my jacks start to degrade, I'll contact Onkyo and get it resolved...the current pricing on the DP-X1 is too hard to pass up.
-Playlists....I have no problem creating playlists that span internal memory and both sd cards. It is rather simple from within the Onkyo Music Player app.
-Equalizer...at first I didn't like it. When I applied any type of equalizer, even "Flat," to certain songs, like .dsf recordings of Shelby Lynne - Just a Little Lovin' and Norah Jones - You've Ruined Me, it seemed to put a veil over the music. These are superb recordings by themselves. However, when I listened to recordings by the Cowboy Junkies and Rolling Stones, the vocals seemed a bit subdued so I again tried the equalizer, and in that case I was able to achieve the opposite effect, basically lifting a veil off the music!
-Cases...I wish Onkyo included at least a basic case. I purchased a very nice, but very expensive PJ red stitch Italian leather case on Amazon. Excellent quality and perfect fit, except there is no cutout for the Play/Pause, FF/REW, etc. buttons on the right side. It is stamped where the buttons are, but very difficult to tap the correct button.
-Screen Protector...I'm using the Lifebox tempered glass. Super easy to install and seems to work perfectly.
-Lastly, I inquired earlier about why the "Line Out" is at max volume if the line output is supposedly bypassing the internal amp. Someone replied that it is because it is the same as the 0db output of the amp. To be honest, I don't understand this...anyone care to "amplify" on this?
That's about it for now. Hope these observations help...
