Silent Xaxal
- May 16, 2014
How does the HD650, DT 1770, and LCD-2 sound on these.
How do the two balanced modes work in practice. do you need specific headphone or connectors for acg and btl i don't get this. also how many hours would you get at high volume in balanced from a full charge? many thanks acg is not from balanced output then??
Many thanks Dave. to simplify you connect your headphone balanced then either switch acg on or off as an option in the player. i assume there is no option switch for btl as thats the standard. finally do onkyo supply the adaptor for 2.5 to balanced.
thanks
im getting a bit confused. if my headphone has the xlr balanced type connection then surely i need a 2.5mm to xlr adaptor? also are the loose headphone sockets now no longer an issue on the dp x1? i understand iem have single balanced cables. (2.5mm male TRRS to single 4 pin XLR Female)
The unit I received about a month ago has a trim plate with no real gap around the 2.5mm & 3.5mm jacks, so they are not able to move side-to-side. Neither do they move vertically (in/out) of the case. So, either I'm really lucky with the unit shipped to me, or the loose jack issue may have been dealt with, as they were tooling up for producing the new DP-X1A.
Take Care,
David Baldock
I'm just gonna repeat what I had said before (buried deep in this thread):
My unit was amongst the first batch of DP-X1(B / original series). Neither jacks have had gaps and still don't show any today.
The 3.5mm jack had even a super tight grip with all of my various 3.5mm TRS cable plugs.
Yet very quickly enough it started to lose that grip and eventually any tiny movement slides it off. And mind you, 1mm sliding up = auto pause cut off.
I'm happy yours don't and hopefully won't have any of this
