ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
post-12848852
Post #11,236 of 16,170
damex
  it is normal output mode without passing built'in amplifer just for bypassing EU cap limit
awesome. thank you. now i finally can drive my dt770 from dp-x1 without external amp :)
post-12850250
Post #11,238 of 16,170
damex
actially ... i compared it to normal mode and it sounds different. i have to compare it thoroughly, but it looks like it is headphone amplifer bypass with just variable volume control... eh (difference voltage for lineout?)
post-12850603
Post #11,239 of 16,170
Jedaite
Hey guys, sorry to barge in. Is the ONKYO DP-X1 better than a Pico Slim/iPod classic combo with TWAG 2 LOD?
post-12851156
Post #11,240 of 16,170
sharkshark
...amusingly, only THIS WEEK the Canadian distributor brought out the units. I've got one put aside, and have tried to keep up with the now massive thread, but curious for those that have had it now almost a year how it's holding up (obvious complaints about loose jacks aside) and if there's a FAQ on the latest quibbles that would help someone finally getting to play with the thing.
Will be running unbalanced at first with Sure 846 - making sure things like lack of hiss, general operability, battery time after a few months, etc.
cheers!
post-12851160
Post #11,241 of 16,170
chef8489
I find the pioneer is better to my ears than my ipos classic and the pico original but not heard the dp-x1. Will let others chime in. I find the pioneer has a wider sound stage, fuller richer sound. The ipod just sounds sterile and boring in my opinion even amped, and i have loved my classic since release.
post-12851320
Post #11,242 of 16,170
damex
i got westone w60 today. disabled variable line out and using normal gain. volume around 90-100 points.
SE for now. looking for BL cable.
is there some amp recommendation to try that might improve sound of dp-x1 + w60?
post-12851427
Post #11,243 of 16,170
chef8489
Whats wrong with the sound?
post-12851509
Post #11,244 of 16,170
Jedaite
Thanks, I'll check it out! And yes, hopefully others will chime in as well.
post-12851567
Post #11,246 of 16,170
chef8489
  nothing wrong. i just have extra to spend for upgrade :)
Here is my opinion. I dont think adding an amp will really improve the sound with the weston w60. I think only adding something like the mojo would and then having the dp-x1 is kinda pointless as it just becomes a transport and thats if the mojo would actually improve the sound. I have not heard the mojo myself, so can not comment on that. If you dont have balanced cables for you w60 yet pick up one either from westone or an aftermarket one and go from there.
post-12851578
Post #11,247 of 16,170
damex
nice, thanks.
dp-x1 interested as transport since it does have some interesting stuff for me as dap like two microSD slots and 5ghz wireless. i am easily fit inside 2x200GB microSD what other DAPs mostly can not (just look at that nw-zx2 or fiio x7). so... mojo might be a good addition. anyway i am searching where to buy locally balanced cable for westone (Hanoi, Vietnam)... no luck :frowning2:
post-12852222
Post #11,248 of 16,170
Bong Hollywodd
  Hope they do something about the damned battery. Worst I've ever seen on a DAP.
I'm getting around 12 hours of play time on mine.  My AK380 cant make it to the 8th hour and the ONKYO has it's wifi on.  So which DAP are you comparing this with?
post-12852226
Post #11,249 of 16,170
Bong Hollywodd
The pioneer xdp-100r
The pioneer xdp-100r will have the same sound signature as the DP-X1 as the internals are almost the same.  The only difference you will see or hear is when the Balanced out is used.
Reactions: Jedaite
post-12852241
Post #11,250 of 16,170
chef8489
I heard they have a different sound signature. I will probably find out next month. Might pick up the dp-x1 for myself and sell my pioneer to a friend that needs an upgrade from his Fiio x1.
Users Who Are Viewing This Thread (Users: 1, Guests: 3)
