cirodts
- Jan 27, 2016
I have just purchased, I do not understand much English but, what are the problems that there are with dp x1 thanks
Anyone knows what the "Media" app is for ?
It's the more draining app in my device.
And i must sometimez erase its data in"Storage" because it occupies a lot of space (several GB).
I think Media manages downloads from apps like Spotify, Tidal, Amazon, Google Music, etc. That's why it has large storage use. It's not the app, it's the media files that it's downloading.
It was the 'problem' when I had battery drain, caused by a Spotify download failing due to running out of storage space. Despite there being no space it appeared to keep retrying the download causing battery drain. I had to reinstall the Spotify app to fix it.
Thanks. But i don't use streaming and never did, i only listen to my library on SD, in airplane mode or stand alone mode.
And i disabled Auto Sync in Music app because there's no change in the content of SDs (128 and 200 GB, about 10K songs).
When local storage space is full because of "multimedia storage", the Music app don't even start.
When i erase all data of "multimedia storage", then Music works OK.
And "Media" drains the battery at the same rate than Music.
As much as i love the DAP, i am now having issues with the 3.5mm headphone jack. My headphones keeps disconnecting with the slightest touch every single time. Does anyone have this issue?
the best player for sound quality and battery is what?
For me the pioneer player is the best for me now giving me good battery and sound quality ( make sure off all the upscaling/ upsampling)..
Regards,
Jonathan
Not recommended upscaling flac-dsd?
and even digital filters?
I had this issue with 2,5mm jack. If disconnecting left ear speaker - just push gently forward with needle gold plated contact on the left side deep inside socket. Turn off device beforehand. Hope, it will help. If no - repair (or return).
Filter is ok..
But it seem for me.. upsample will consume more battery.
Draining faster for me.
Thanks,
Jonathan
