just thought that i'd share an update with the battery issues that i was facing. with help from the good people here, i did reset my device & disable most of the apps that i would never use but all that didn't have a positive impact on the battery drain issue. so i searched this same thread & discovered that a few others have also faced this issue.
this seems to be a wifi power management issue that may be fixed with a future firmware update by Onkyo. for the time being, whenever i am done listening with the onkyo, i put it on standalone mode, cutting off the wifi connectivity while it is on idle mode. this seems to be preventing the battery drain while on idle mode issue. this is not an ideal solution but seems to be a workaround. i hope someone @ onkyo will fix this issue for good with the next firmware update.
