Johnny Woody
- Jan 26, 2015
If you read my review, I did use silver cables with the bright th900 headphones. No, it is not and will not introduce piercing highs, unless you got scammed by cheap quality silver-plated cables.
I can totally confirm that it is and will be the best upgrade for your little DAP.
http://www.head-fi.org/products/onkyo-hi-res-sound-source-corresponding-digital-audio-player-32gb-dp-x1/reviews/15089
Second that (second the second of my recommendation)
Also, my UM50pro is well known for its mid and bass.
That's why a 99.9 8n silver cable is not piercing at all.
PS: you may need to switch to low or normal gain before fully run-in the cable.
