A gorilla told me last night that this DP-X1 did in fact use the glass made by his family member.![]()
Dr. Doolittle?
My impact audio cables are built with eidolon mmcx connectors for Shure SE535 with absolute no hiss.
Yes, SE 3.5 to Balanced 2.5 is bad juju. But not swapping a cable line from a 1:1 trrs 3.5 with an adaptor 2.5 on will not short the system.
Right side ear cup (-r=+l, +r=+r)
Left side ear cup (+l=-l, -l=-r)
From what I'm seeing no shorten line. But what do I know I'm just an electrical engineer.
weird... because I have the exact setup and hissing happens when I'm on any 3rd party music player (Tidal, apple music and sound Cloud) on the local music player yes it's clean but the sound coming out of the BALANCE out is too minuscule coming from the SE535. I only use it now to work out. My bigger cans are the only thing i plug on my DP-X1 balanced.
Hrm, so you're saying volume for balanced with Shure IEMs is weak? That seems like a deal breaker if true on needing a balance cable... Gah, this shouldn't be this hard.
My 846s are way harder to drive than the 535s.
You can also say that after running my EL-8 balanced on the DP-X1, everything else is doesn't compare no (until I finish my Balanced cable for my OPPO PM-1).
I still use the SE 535 but for something that quality of sound is not necessary. Like working out, working in my garage or making skins for the DP-X1.
same here+5 on the Dignis and +1 on the tempered glass
