philk34
- Feb 8, 2015
It is weird. Nobody ever talked about player being unstable. Thanks for letting us know.
Is it possible to use the DP X1 as USB DAC? If not, do you think it will get the capability through firmware update in the future?
This question was answered a few pages back - http://www.head-fi.org/t/780642/onkyo-dp-x1-dual-sabre-dacs-balanced-sabre-btl-amp-mqa-dsd-256-android-5/2280#post_12180917
I would not count on the capability being implemented, as there have been no mention by Onkyo/Pioneer of such a thing being in the works.
When in doubt, assume the worst.
And a firmware upgrade would not be sufficient, it would require a driver as well.
Hmm, am in Singapore, but haven't got it
Wonder how are they pushing the updates out.
Howdy All!
I have an Onkyo DP-X1 on the way from Japan!
I own several headphones including Sennheiser HD700 / HD800.
I would like to use the headphones with the 2.5 balanced output on the Onkyo.
What cables to I need to buy? I see the balanced cables have a different ending connector and requires yet an additional plug to convert it to the 2.5 balanced output jack on the DP-X1!
Thanks in advance and Merry Christmas!!
Best,
Aggie85
P.S. Please include URLs to your suggestions!
Android OTA updates are a bit of a lottery system. If you're lucky, you get it. If not, you have to wait.
You can only get the update otherwise if someone has a URL then you flash it via recovery.
Lucky ! Just got it OTA![]()
Let's see if this fixes the crashing nonsense.
Mine came down already. Not really finding any major differences.
Get any aftermarket cable and have it terminated to 2.5 . Don't even try to convert 3.5 to 2.5 , it doesn't work that way
You could, but that would degrade sound quality a bit. Then the regular TRRS to TRS adapter AK style was going for 60-70 a piece. I can see things more specific would cost even more. Then yeah, best to buy another cable just like you said .
