I don't believe so. From what I've read, the only way to access MQA is to directly download it through the Onkyo or Pioneer sites. https://www.onkyomusic.com/US/home?select-country=trueIs it possible to use the DP-X1A as a USB DAC for my MacBook Pro? I have the Tidal app but on the Android version, but it does not allow MQA playback. That option is only available on the Desktop app and I've yet to try listening to MQA.
TIA
ONKYO DP-X1 | Dual Sabre Dacs | Balanced | Sabre BTL Amp | MQA | DSD 256 | Android 5 |
- Thread starter T.R.A.N.C.E.
DBaldock9
TIA
While I wasn't following the DP-X1 at its launch, there was some speculation here that it might / would support USB DAC functionality.
But, I don't think I've ever seen anything official from Onkyo, saying it was a feature that would be added.
Thanks. looks like I'll need to get a DAC for my laptop. I have a previous gen Audiofly but I've heard great stuff about the Meridian one and it does MQA.
mrmoto050
The iDSD if I nanoThanks. looks like I'll need to get a DAC for my laptop. I have a previous gen Audiofly but I've heard great stuff about the Meridian one and it does MQA.
black plays MQA from Tidal Desktop app.
fordski
The iDSD if I nano
In this case the Tidal app is doing the first unfold of the mqa file. I don’t believe the iDSD unit does any further processing. Most DACs will be able to play the Tidal MQA output but you need a DAC with MQA capability like the meridian to do the second unfold.
mrmoto050
It has MQA capability according to specs.In this case the Tidal app is doing the first unfold of the mqa file. I don’t believe the iDSD unit does any further processing. Most DACs will be able to play the Tidal MQA output but you need a DAC with MQA capability like the meridian to do the second unfold.
fordski
My apologies. I didn’t see it listed in the specs but see there’s been a firmware upgrade to add it to previous units back to 2013. Cool!
The Dragonfly Red does MQA.Thanks. looks like I'll need to get a DAC for my laptop. I have a previous gen Audiofly but I've heard great stuff about the Meridian one and it does MQA.
swesko
- Mar 27, 2016
MQA is overhyped or my ears are not picking up any differences. I play the same tracks with the same setup and I dont hear any difference from the same track in FLAC. So if you are basing your purchase solely on mqa I suggest you try before buying
Personally, I think it's a marketing ploy.MQA is overhyped or my ears are not picking up any differences. I play the same tracks with the same setup and I dont hear any difference from the same track in FLAC. So if you are basing your purchase solely on mqa I suggest you try before buying
mrmoto050
It's all good, no worries. It sounds great by the way. Shows a Magenta glow.My apologies. I didn’t see it listed in the specs but see there’s been a firmware upgrade to add it to previous units back to 2013. Cool!
piotrekwoj
Any solution for the brightness problem?
fordski
I actually have an older iDSD Micro and this discussion alerted me to the availability of the MQA firmware update, so I'll get to try it for myself....Thanks!
colonelkernel8
90% of the audiophile world is a marketing ploy my friend.Personally, I think it's a marketing ploy.
I’d just like to hear MQA for myself...
Total: 9 (members: 0, guests: 9)
