- Oct 14, 2013
Man, I am surprised that he did even write a great review in his situation !
Hello there
Quick feedback (after 2 years and half of using it)
(it is hard to describre, but when tears flow during a listening session (and you do not know why), it transports you into the extraordinary nature of music (as well as other expressive arts), it doesn't mean anything, but it's always difficult to put into words a feeling/an experience).
P.S. didn’t read the forum rules yet, so I hope its okay to forward this kind of linkDear team,
as a recent viewer of this clearly pro thread, I felt responsible to forward the fresh info (confirmed via phonecall) about DMP-Z1 availability in Switzerland (overpriced though) with international shipping:
https://digistore.ch/fr/4710-8166-dmp-z1.html#/1-couleur-noir
All the best
"Depending on supplier availability" and yes, way overpriced and you need to add tax even if ordering from Europe as Switzerland is not in the EUDear team,
All the best
Thanks... but I thought that the Z1 was discontinued ?!Dear team,
All the best
Doug2507:Don't think you can get the exact same one but if you go into the DMP pdf spec sheet available on Sony website, it gives you the serial number of the PSU. Good it and its just a cheap-is laptop charger. Readily available.
Edit, still got the screen shot..
And as for battery, I've got mine on loop with a burn in track with AC plugged in but not selected battery preferred so it won't be using any battery during burn in. Been unplugging / listening a couple of hours a night for the past few nights but away with work for 2-3 weeks and left it plugged in on loop. When I get back I'll probably drain battery to 20% then cycle it 20-80% a half dozen times then start using it in earnest. Fully plan to pair it with either a DIY LPSU with protection or just get an HDPlex 300w and run it off that unless I'm moving room.
Got that from Sony UK support section for DMP, just a screen from the DMP docs. Also cross checked the charger part number online and got the same spec.Doug2507:
Do you know if the pdf is still available or where I can upload it ? Because I’m thinking of making myself a
lpsu for my dmp-z1, and I would like to know the current requirement for the 19.5 VDC DC power supply. On your screenshot it is indicated VDC=19.5V, 2.35A and 45.8W, do you think values are correct ?
also on mediamarkt.ch there is ‘availability and confirmation after validation with supplier’..also at the initial price…Thanks... but I thought that the Z1 was discontinued ?!
Hello all,
Can someone tell me the exact type of Barrel jack connector for 19.5VDC, I don't think it's Barrel jack (5.5mm OD x 2.1mm ID) or Barrel jack (5.5mm OD x 2.5mm ID). I tried to find this information on internet but I didn't find it...
