Kiats
Pulled out the Final Sonorous X for a spin with the DMP. Since I was putting it through its paces with the TAZ. Still as musical and lush as it has always been. Old friend.
The Final are an excellent Match to Sony's sound signature.Pulled out the Final Sonorous X for a spin with the DMP. Since I was putting it through its paces with the TAZ. Still as musical and lush as it has always been. Old friend.
E5000, A8000, D8000, all excellent Matches.
gerelmx1986
@Whitigir the amp section of the TA-Z1HES is class A or class A/B? I know DMP has a TI TPA amp which is A/B
- Oct 14, 2013
Definitely A/B@Whitigir the amp section of the TA-Z1HES is class A or class A/B? I know DMP has a TI TPA amp which is A/B
It should be this
Wikinaut
Why does the DMP require me to turn down the volume 0 whenever it comes out of standby? It's the only audio processor I have that requires it. Curious why that is.
gerelmx1986
Ro p ot cr tour heqring from a possible sudden loud volume output. For example if tou forgot that you were playing out loud mueic with a set of Planars and then you devide to use IEMWhy does the DMP require me to turn down the volume 0 whenever it comes out of standby? It's the only audio processor I have that requires it. Curious why that is.
gerelmx1986
@Wikinaut you can deactivate it on settings. But then you are subjected to forgetfulness. In previous post i mean to protect your hearing
Wikinaut
Thanks! I never connected the dots with "Auto Muting" in the settings. I tend to use the same headphones all the time, so it should be safe to turn off.
Kiats
Some Sunday morning listening on the DMP streaming from the DX300 into the LCD3.
gerelmx1986
Why not as USB DAC instead of BluetoothSome Sunday morning listening on the DMP streaming from the DX300 into the LCD3.
xjaynine
- Aug 7, 2011
Does anyone know where to find the service/ parts manual for the DMP? Google search is not showing up with anything. Looking to buy a volume knob for DIY project
Kiats
I am using USB DAC from my Melco N10P as Roon endpoint into the TA-ZH1ES.Why not as USB DAC instead of Bluetooth
I've seen some tests that showed, that an LDAC Connection is pretty much identical to an cable connection.
This have to be taken with a grain of salt as this assumes an perfect conneciton which, of course, can not always be guaranteed. But there was one guy measureing the output using USB DAC and Bluetooth and comparing them and did not find any difference.
But it was just one guy doing one test, it seems the interest ins not big enough to do any further testing as most audiophiles just don't use Bluetooth at all.
But i use my DAP as Bluetooth Receiver quite often, especially outside the house, and i have not heard any difference in sound quality yet.
But i always force highest quality which, sometimes, causes connection issues. So skipping parts and stuff like that when there are a lot of disturbing signals like on big train stations.
MrWalkman
https://www.dropbox.com/s/du6ld6l08bk0v49/DMP_Z1_service_manual.pdf
